cjgear26
Nov 29, 2020Follower
Powerline 2000 + wifi extender
Hello. I have a Powerline 2000 installed so that the internet connection is running through the electrical system. I'm wanting to add one of the units with the antenna so that one of the member in my...
Nov 30, 2020Guru - Experienced User
You can. the PLP2000 uses homeplug AV2 standards. So any homeplug AV2 device would work with it.
Just keep in mind, home plug devices will use the speed of the lowest performing device.
