xsdfadad
Sep 22, 2021Aspirant
powerline av 500 / xav5401 | new internet speed but it doesnt work over powerline
Pls I beg you someone help me. two days ago our internet speed doubled and it works fine wifi wise but the internet speed via the powerline is still the old one. I reset the devices uncountable times...
xsdfadad
I also have a thrid device connected to them, the XWN5001, that should be a newer one I think and that one also doesn't transmit the full 100k
Sep 22, 2021Guru - Experienced User
all those devices are AV500 powerline devices.
Powerline is sensitive to interference as well as distance. I'd highly recommend reading a few tested reviews on these devices.
I'd also keep in mind, that they're speeds drop quickly in seperate circuits. The reviews I link to will show tested speeds. 1 test on the same circuit and a couple on different circuits (most homes).
https://www.smallnetbuilder.com/archives/lanwan/lanwan-reviews/31624-homeplug-av-500-adapter-roundup
Another thing to be careful of, if you do upgrade, powerline functions at the speed of the slowest device. So if you upgrade to AV2000 devices but keep your AV500 device connected, you'll get the slower speeds.
- xsdfadadSep 22, 2021Aspirant
So you would say that an upgrade would fix the problem? Like for sure or is that just a possible fix. Which kit would you recommend? I really have no idea about that I'm sorry xd
- plemansSep 22, 2021Guru - Experienced User
Would it forsure fix the slow down? No clue.
Each home is different. and some homes dont' work well for powerline devices because of wiring, interference, distance, etc.
So I can't say 100% it'll fix your slow down.
Why are you using powerline?
have you looked into mesh systems or moca adapters?
how big is your home?
What are the interior walls made of?
