xsdfadad
Sep 22, 2021Aspirant
powerline av 500 / xav5401 | new internet speed but it doesnt work over powerline
Pls I beg you someone help me. two days ago our internet speed doubled and it works fine wifi wise but the internet speed via the powerline is still the old one. I reset the devices uncountable times...
xsdfadad
So you would say that an upgrade would fix the problem? Like for sure or is that just a possible fix. Which kit would you recommend? I really have no idea about that I'm sorry xd
Sep 22, 2021Guru - Experienced User
Would it forsure fix the slow down? No clue.
Each home is different. and some homes dont' work well for powerline devices because of wiring, interference, distance, etc.
So I can't say 100% it'll fix your slow down.
Why are you using powerline?
have you looked into mesh systems or moca adapters?
how big is your home?
What are the interior walls made of?
