Eric150921
Aug 17, 2021Aspirant
powerline PL 1000v2 adding extra outlet
Hello I have a 1000V2 that works fine at home but I need an additional outlet to reach more rooms in my house in France. I am not sure what outlet to buy, can I buy the EX61300 or the EX 730...
michaelkenward
Aug 18, 2021Guru - Experienced User
Eric150921 wrote:
Hello
I am not sure what outlet to buy, can I buy the EX61300 or the EX 7300 to add to my existing ?
Like plemans, I am confused.
The PL1000v2 is a Powerline plug. The EX6130 and EX7300 are wifi range extenders. You can't add them to Powerline
What do you want to add? More wired outlets? More wifi sources?
I use Powerline to connect an Orbi router in AP mode to my main router.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Powerline Networking - NETGEAR Communities
Eric150921
Aug 19, 2021Aspirant
Maybe I need to reword :
I currently have a Powerline 1000V2 in my home. I bought it few years ago because some part of my house where too far from my router and i could not get any wifi in these rooms.
Now I want to reach (i.e. provide wifi) even more rooms that are even further away.
What would you suggest/advise I do on to my exisitng system (Powerline 1000 V2) in order to reach (have wifi) more rooms that are further away ?
hopefully clearer now
- michaelkenwardAug 19, 2021Guru - Experienced User
Both the answers you received still apply. You haven't added much in the way of new information.
My first move would be to see if you can get your existing equipment to provide wifi in the rooms you want to reach.
If that works, then decide if you want to buy more Powerline equipment, with or without built in AP, or if you want to use wifi extenders, either in repeater or AP mode.
