SumanthD's avatar
SumanthD
PPPoE is not working
I have recently configured PPPoE in my Router. It was working fine for some time (4-5 days). After that it stopped working.   If I change the setting (Does your Internet connection require a login...
  • DexterJB's avatar
    Aug 28, 2017
    Hi SumanthD,
    1. Please confirm with your ISP if your connection should be configured as PPPoE.
    2. If the DHCP settings work, it is most likely that that is how it should be configured.
    Dexter
    Community Team
