pukunui
Jul 11, 2016Aspirant
PR2000 bricked - can it be fixed?
Hi there, Last night I stupidly tried updating the firmware to v1.0.0.15 on my PR2000 via the wireless. Needless to say, it appears to have corrupted the device. The wifi no longer works (when I ...
- Jul 11, 2016
Sorry to hear that. Sounds like it is really messed up. If I were you I'd bite the bullet and go for new replacement. To have any hope at least CFE (common firmware environment) should be intact. Sorry again.
pukunui
I did try pinging it with the cmd prompt. Got nothing. I will try tftp. Thanks!
VE6CGX
Jul 11, 2016Master
Unable to ping and you want to try tftp? When access to router is impossible, what tftp is gonna do? Firs thing in order is hard reset the router
to bring it back tp default router mode. When you press the reset button how long do you hold it down? You should hold ir down until indicators
start blinking and let go of the button. Purpose if hard reset by button is initiallize the router and when all is well to boot it up to ready state.
