pukunui
Jul 11, 2016Aspirant
PR2000 bricked - can it be fixed?
Hi there, Last night I stupidly tried updating the firmware to v1.0.0.15 on my PR2000 via the wireless. Needless to say, it appears to have corrupted the device. The wifi no longer works (when I ...
- Jul 11, 2016
Sorry to hear that. Sounds like it is really messed up. If I were you I'd bite the bullet and go for new replacement. To have any hope at least CFE (common firmware environment) should be intact. Sorry again.
pukunui
I have no idea what I'm doing here, to be honest. I didn't realize tftp wouldn't work if pinging didn't work.
I have tried using the hard reset button. I've held it down for at least a minute with no change to the lights. I'm not getting any blinking or change in color or anything. It's not rebooting.
VE6CGX
Jul 11, 2016Master
- pukunuiJul 11, 2016Aspirant
Rats. Well, thanks anyway!
EDIT: VE6CGX Hang on, I just tried the reset button again with the router on wireless and the USB light is now blinking. None of the other lights are, though. Is that a good sign?
Having the USB light blinking didn't seem to make any difference. I've gone and bought myself a WN3000RP range extender as a replacement. Hopefully it'll work just as well (if not even better) than the PR2000.
- VE6CGXJul 11, 2016Master
I can't even guess what status the unit is in for now. It's called result unknown after failed attempt to update the firmware.
