andy_
Oct 11, 2016Aspirant
PR2000 VPN issues from iphone (openvpn client)
Hi! I recently purhased the N300 Trek Travel Router and Range Extender 802.11n. When using an IOS (eg iPhone, iPad, etc.) device behind the PR2000, I cannot connect to my VPN server. I hav...
- Nov 29, 2016
Great points and very well said AFNYC84!
From a customer perspective, stating "EOL" clearly is critically important for any purchase. Pass through for all major VPN types should be tested/ included by default regardless of EOL (IMO).
FYI: After a fair amount of work, I did get IPSec to work through the PR2000. Although, now I need to support 2 VPN options instead of just 1 - which means extra (unnecessary) work.
ElaineM
Oct 12, 2016NETGEAR Employee Retired
Hello andy_
Welcome to the community!
Can you try it on Android? Just to confirm if this only happens on mobile devices.
andy_
Oct 17, 2016Aspirant
Hi Elain,
Thanks for your reply.
I finally tested this on my Galaxy 7.
Same issue with Android as with IOS.
Getting "stuck" during the DNS lookup process.
Any ideas / solution thoughts?
Thank you in advance!
- ElaineMOct 17, 2016NETGEAR Employee Retired
Let me check this with our engineering team.
Will get back to you as soon as I have response.
- AFNYC84Oct 17, 2016Initiate
Hi Elaine,
I am having the exact same issue as the original poster, Andy_.
I would also be very interested in hearing any information the engineering techs have to say about resolving this issue.
Thank you.
- andy_Oct 25, 2016Aspirant
Hi Elain,
Any update to this issue?
Thanks!
