andy_
Oct 11, 2016Aspirant
PR2000 VPN issues from iphone (openvpn client)
Hi! I recently purhased the N300 Trek Travel Router and Range Extender 802.11n. When using an IOS (eg iPhone, iPad, etc.) device behind the PR2000, I cannot connect to my VPN server. I hav...
- Nov 29, 2016
Great points and very well said AFNYC84!
From a customer perspective, stating "EOL" clearly is critically important for any purchase. Pass through for all major VPN types should be tested/ included by default regardless of EOL (IMO).
FYI: After a fair amount of work, I did get IPSec to work through the PR2000. Although, now I need to support 2 VPN options instead of just 1 - which means extra (unnecessary) work.
andy_
Oct 17, 2016Aspirant
Hi Elain,
Thanks for your reply.
I finally tested this on my Galaxy 7.
Same issue with Android as with IOS.
Getting "stuck" during the DNS lookup process.
Any ideas / solution thoughts?
Thank you in advance!
ElaineM
Oct 17, 2016NETGEAR Employee Retired
Let me check this with our engineering team.
Will get back to you as soon as I have response.
- AFNYC84Oct 17, 2016Initiate
Hi Elaine,
I am having the exact same issue as the original poster, Andy_.
I would also be very interested in hearing any information the engineering techs have to say about resolving this issue.
Thank you.
- andy_Oct 25, 2016Aspirant
Hi Elain,
Any update to this issue?
Thanks!
- ElaineMNov 18, 2016NETGEAR Employee Retired
I apologize but since PR2000 has been considered EOL, there will be no future firmware to be released for this product.
- andy_Nov 22, 2016Aspirant
Thank you for your reply!
It it is very much appreciated.
i must admit I am disappointed though. It would seem that this is a very basic functionality.
i like the functionality of wisp and LAN plus NAT FW and USB charging; however, had I known the lack of VPN support I would not have purchased it.
i travel where I regularly connect to insecure hotel wifi and use VPN as a means of protection against eavesdropping.
is there anything that can be done to assist?
Thank Ng you in advance.
