rungel
Nov 22, 2015Tutor
Print sharing stopped working in windows 10
Hi all,
Running Windows 10
Cisco DPC3208 modem
WNDR3800 router
I have reset the router to factory setting and still will not print anything. Also the desktop is in the same problem. Router has firmware 1.0.48
Modem not sure what firmware that is..It was working not sure what happened..
Thanks Bill
I got it fixed.. it needed a driver from the canon site..for anyone needing the lazer printer LBP6000 driver here it is.
http://support-sg.canon-asia.com/contents/SG/EN/0100298301.html
- rungelTutor
also tried setting the printsharing in the netgear genis.. but it will not hold
- Retired_Member
Try installing as a administrator. I've found several programs that only worked when installed as admins.
- rungelTutor
