Net_Gear_Man
Feb 19, 2019Initiate
printer not connecting to network AC1750 WiFi Cable Modem Router C6300-100NASer
First time on this forum and adding a question...
I just installed a HP wireless multifunction printer/scanner/copier/fax.
I have an access control list on my NetGear C6300. Although I WAS able t...
- Feb 19, 2019Following further discussions with hp technical support personnel it was found the first technician had installed the same printer with the Microsoft operating system twice! Removing the duplicated one solved the paradox.
Glad to read your proposed solutions.
antinode
Feb 19, 2019Guru
Does HP make only one model of those, or does yours have a model
number of some kind?
> [...] Although I WAS able to enter the MAC address into it, it doesn't
> display it. [...]
How did you determine this "the MAC address"? If your (unspecified)
"a HP wireless multifunction > printer/scanner/copier/fax" has more than
one network interface, then each one might have its own MAC address.
> I have an access control list on my NetGear C6300. [...]
I'd disable it, get the printer connected, and _then_ worry about any
problems with access control (_after_ you're sure about the printer's
MAC address).
