kevincorn
Nov 21, 2016Aspirant
Printer Won't Connect to Network
I installed a new wireless router 2 days ago and since then have not been able to get my printer to connect to the network. It worked just fine prior to installing the new router. Netgear customer ...
- Nov 22, 2016
Everything worked fine & I could print directly from the computer to the printer. I finally just wound up uninstalling the printer and reinstalling it. That seems to have worked . . . so far.
ElaineM
Nov 22, 2016NETGEAR Employee Retired
Hi kevincorn
Welcome to the community!
How will the printer be connected to the router?
Wired or wireless connection?
If it's wireless, make sure that you have the correct wireless password to connect it to the wireless network.
Think of it as a wireless laptop that will be connected to the network.
However, if it will be connected through wired make sure that the cable is inserted securely to the port on the router.
By the way, what's the model of the printer?
kevincorn
Nov 22, 2016Aspirant
It is a wireless connection that worked just fine with the previous routers I've had. The printer is an old HP2542 all in one. Right now the network will not even recognize the printer.
