kevincorn
Nov 21, 2016Aspirant
Printer Won't Connect to Network
I installed a new wireless router 2 days ago and since then have not been able to get my printer to connect to the network. It worked just fine prior to installing the new router. Netgear customer ...
- Nov 22, 2016
Everything worked fine & I could print directly from the computer to the printer. I finally just wound up uninstalling the printer and reinstalling it. That seems to have worked . . . so far.
ElaineM
Nov 22, 2016NETGEAR Employee Retired
Make sure that you can print first directly to the computer.
Then once you have established that you should be able to see the wireless signal of the router to connect to it.
Are there any other devices that can connect to the router wirelessly?
kevincorn
Nov 22, 2016Aspirant
- ElaineMNov 23, 2016NETGEAR Employee Retired
Thank you for the update.
Should you have any other concerns let us know.
