rltorson
May 10, 2018Tutor
Printer Won't Connect to Network
For over two years I have been using my printer (HP Photosmart 2610Xi) connected to the router via a LAN port on the router as this allows me, using the NetgearGenie Air Print feature to print using ...
- May 13, 2018
Got it going. Trick was to reset printer to factory default, open System Preferences and delete the printer then re-install it then open Netgear Genie and reselect the printer in Air Print. Now I can (again) print from my iPhone or iPad even using my antique non-airprint printer
michaelkenward
May 11, 2018Guru - Experienced User
Your "footer" says you have an WNDR4300. You also say that you have something called an an SB6141. What is that?
How is all this stuff wired together? And what is the modem that feeds this complicated array?
