FNG
Mar 16, 2016Tutor
Printer won't connect
Unable to acess my Brother MFC-465CN printer (non-WiFi) on my network. I have it connected via ethernrt cable as I've done in the past with other modem/routers. I have checked the cable and tried ot...
- Mar 19, 2016
Thanks for the help netwrks. After many frustrating hours, I ended up stumbling upon the solution by just doing a Factory Reset on my printer. After that, the printer was "visible" to all our devices and we can now print via WiFi.
netwrks
Mar 16, 2016Master
You can give the printer a static IP address using the printer menu to input data. Printer Manual - Menu - Pge 141 - Network Page 145.
FNG
Mar 19, 2016Tutor
