Howard16
Sep 06, 2016Aspirant
Printer won't connect
Time Warner gave me a new modem and now I can't connect my Brother wireless printer to the network. The router is wired to my destop and I can't logon to it (IP 192.168.1.1) from the desktop. However...
- Sep 12, 2016
Elaine,
Thanks for your reply. I have resolved this. For whatever reason, my network will not recognize my printer from my desktop. I connected a USB cable from the desktop to the printer and it prints. My network does recognize my printer from my laptop. My printer does print wirelessly from my laptop. That my desktop is eight years old probably has something to do with it.
Howard
Howard16
Sep 07, 2016Aspirant
Thanks for your reply. The modem is a Ubee.
I have not been through the trouble shooting steps. I will do that.
Howard
michaelkenward
Sep 07, 2016Guru - Experienced User
And the printer model?
- Howard16Sep 07, 2016Aspirant
Sorry.
Brother HL-2270DW
- ElaineMSep 08, 2016NETGEAR Employee Retired
Looks like your printer is capable of wireless connection.
Are all your computers connected to the internet?
If it does, all you have to do is to connect this printer to the wireless network.
Make sure that you have the correct name to connect to and the wireless password.
- Howard16Sep 10, 2016Aspirant
Well, it's partially resolved.
My modem (Ubee) and router (Netgear) are wired to my desktop. Following the instructions from Brother, I attached an ethernet cable from the printer to the router and obtained a valid IP address. I opened a browser from my desktop and entered the IP address. The Brother Web Management screen would not open. However, I went downstairs and entered the IP address in a browser from my laptop (wireless) and the Web Management screen opened right up. I followed the instructions and my printer now works wirelessly from my laptop.
The printer will not work from my desktop. I get a printer error message. Also, I cannot access my router (IP address 192.168.1.1) from my desktop, but I can from my laptop.
Do you have any ideas about why I can't get the printer to connect from my desktop? I guess it has to do with the new cable modem Time Warner gave me.
Thanks,
Howard
- ElaineMSep 12, 2016NETGEAR Employee Retired
Sounds like a desktop problem.
What's the IP address of your desktop computer?
Is the desktop directly connected to the router using ethernet cable or this is also running wirelessly?
The reason why you cannot access the admin page of the router is that the desktop might not have the correct range of IP address.
- Howard16Sep 12, 2016Aspirant
Elaine,
Howard
