routerguy25436's avatar
Sep 13, 2023
Problem after factory reset
After doing a factory reset, I am able to connect to the netgear network, but am unable to use the app or connect to the control panel. The app keeps saying router not found. I have cycled both my modem and the rotuer. Please help.
  • FURRYe38's avatar
    Try connecting with a ethernet connected PC and web browser pointed at 192.168.1.1
    • routerguy25436's avatar
      routerguy25436
      So, I tried 192.168.1.1, 192.168.0.1 in both http and https. I did it with a direct connection via ethernet on a desktop and also tried connecting to both the the standard netgear network and the 5Gigahertz netgear network on both my mobile and desktop. I cannot get to the admin screen. I've checked my modem (xfinity) and everything seems correct there, though I may be missing a setting that's causing a problem. Any suggestions are more than welcome.
      • FURRYe38's avatar
        What is the IP address your PC is getting from the router when it's ethernet connected?
        There a router build in to the ISP modem/ONT?
