neishah
Nov 15, 2016Aspirant
problem connecting with sony bravia tv
I have tried everything. The t.v. has a USB adaptor, which the t.v. recognises. However, the LAN and WAN are always on "fail" and the t.v. settings are always on ip address starting with 169.... w...
- Nov 17, 2016
Thank you so much to all who contributed assistance for my internet issue.
I got so fed up with it all, I went out and purchased a wifi extender............. I now have internet t.v.!! with 5 bars!!
The t.v. obviously didn't like the distance from the router.
Have a nice day!
neishah
Nov 16, 2016Aspirant
Thank you, but that made no difference. I really appreciate everyone's assistance for this problem, it is doing my head in! I bought the D6200 as an upgrade from the 2200, thinking it would do a better job, so I don't want to have to spend more money on this issue if I can help it.
Retired_Member
Nov 16, 2016what security settings are you using for WIFI
- neishahNov 16, 2016Aspirant
I am using this: WPA2-PSK [AES]. I have tried changing the security settings, even using "none" at one stage.
- Retired_MemberNov 16, 2016
verify you have wifi signal in room where TV is located
tv model #
USB adapter model #
WIFI router settings 2.4 & 5g
yes have wifi signal in the room where tv is located, as I can use my laptop and mobile.
T.V. Model KDL 40EX650
USB Adaptor Sony UWA BR100
- neishahNov 17, 2016Aspirant
Have a nice day!
- Retired_MemberNov 17, 2016
Great news,
I meant to correct an earlier post regarding AP. A wireless bridge could also be used It receives or connects to your router and uses a data cable to connect devices which do not support WIFI. It can be located in a location with good signal and then run a cable to the device.
Extenders or repeaters can be a pain in the a$$ when streaming video.
just a thought
- michaelkenwardNov 17, 2016Guru - Experienced User
@searay wrote:Extenders or repeaters can be a pain in the a$$ when streaming video.
Which is one reason why I usually suggest the simpler, and sometimes cheaper, Powerline alternative.
I have fought with wifi on smart devices and it stinks.
It is a pity that Powerline is still relatively unknown, and that earlier implementations put off many people.
I am using a Netgear Dual Band WiFi extender, it has been working like a dream. I binged on Netflix last night!
- michaelkenwardNov 18, 2016Guru - Experienced User
