varonica_1
Nov 29, 2019Initiate
problem in accessing default gateway
Hello Friends I am using netgear R6220 Ac 1200. I am very bad in tec. So i have tried to access 192.168.1.1 router login page. Even I visited www.routerlogin.net I dont know why my IP is 192.168.14...
- Nov 29, 2019
What modem are you connected to?
many times people are running a modem/router combo device and then hooking another router to it. it causes many issues and the one you're having can be one of them.
https://kb.netgear.com/30186/What-is-Double-NAT
If this is the case, you'll either want your combo device in pass through/gateway/modem only mode or you'll want to disable wifi on it and enable access point mode on the netgear device.
Nov 29, 2019Guru - Experienced User
