bootaz
Jan 03, 2021Aspirant
problem updating firmware for AC1200
I am having two problems with my Netgear AC1200 router. Problem 1: I have been unable to do any updates, firmware or software, to my router for months now. I cannot even get to the proper page. I ...
Jan 03, 2021Guru - Experienced User
1. What modem/gateway do you have?
2. Do you know what firmware is on it?
3. If you can't get into the router via the password recovery option, you can always factory reset the router and reinstall it. That'd get you back to dafaults to get you back in. to reset, push and hold reset for 7-15 seconds while its powered on.
bootaz
Apr 03, 2021Aspirant
I have done a factory reset on the router at least 3 times.
