helponhand
Oct 19, 2021Aspirant
Problems buying from Netgear UK
Purchased a WAX214 through Netgear.co.uk & received a GS324 switch. I tried to contact them multiple times, but they seem either not interested in taking back the wrong item they sent or refunding me...
- Oct 20, 2021
Looks like Netgear farms out the "store".
Check the bottom of this page:
Netgear UK Store | Buy Wifi Routers, Mesh Wifi & Range Extenders.
Who or what is Exertis UK Ltd?
"©1996 - 2020 NETGEAR ®" is a bit worrying.
Did you find this?
Contact Customer Service by email on– netgearstoresupport@exertis.co.uk
On this page:
Frequently Asked Questions | Netgear UK Store
michaelkenward
Oct 20, 2021Guru - Experienced User
Did you find this?
On this page:
- helponhandOct 20, 2021Aspirant
Yup,
I found out that netgear.co.uk is Exertis UK Ltd and they are totally unresponsive.
Tried calling and emailing and got nowhere.
If you live in the UK buy from Scan.co.uk not netgear.co.uk as you will actually get support if anything goes wrong.
- michaelkenwardOct 20, 2021Guru - Experienced User
I have never tried buying from Netgear. I have my own favoured supplier. Preferably not Amazon.
I have used Scan in the past but I recently needed a motherboard that seems to be unavailable here and I ended up buying from a German outlet. (Yes, they do still supply to the UK!) Just as quick as many UK suppliers.
- ChristineTOct 21, 2021NETGEAR Employee Retired
Hello helponhand ,
I'm really sorry to hear about the issue(s) you're having with getting support for your purchase. Let me see if there is anything I can do from this direction to ensure this issue on the right track to get corrected. Can you please send me a private message (pm) with your order details so I can follow up with our internal team?
Many thanks for your patience!
Christine!
