WINZIGG
Aug 09, 2020Follower
Problems connecting to a Google Nest
Hi all I am a complete novice on setting up networks so need simple instructions. Recently purchased a Nighthawk Voice Cable Modem (CM1150V) Installed and activated modem with IS provider and h...
Jeremywp123
Oct 13, 2025Aspirant
The solution seems to be to enable IGMP (Internet Group Management). Then restart your nest device. This is the protocol google uses to stream content and it seems to be disabled by default.
