Retired_Member
Oct 20, 2021Problems with connection after iOs update R6700v3
After update to iOs 15.0.2 on phone and 11.6 Big Sur on macbook, I've had problems with getting kicked off wifi. Checked modem using ethernet and it works fine. I believe it is the Nighthawk R6700v3 ...
Retired_Member
Oct 20, 2021Firmware Version is 1.0.4
I changed the settings to what you recommended and I'll see how things work. When I changed settings to 48 on 5g there was a message that indicated that you get better performance with higher settings? No performance isn't better, but do you think I should change that later and see what happens? If so, is there a higher number you recommend?
Oct 20, 2021Guru - Experienced User
Sure. You can try channels 149 thru 161 and see.
