Retired_Member
Oct 20, 2021Problems with connection after iOs update R6700v3
After update to iOs 15.0.2 on phone and 11.6 Big Sur on macbook, I've had problems with getting kicked off wifi. Checked modem using ethernet and it works fine. I believe it is the Nighthawk R6700v3 ...
Oct 20, 2021Guru - Experienced User
Possible that iOS and new OSX have introduced problems on these devices with older model routers. Apple introduced Private Security which means they randomly change the devices MAC address. This seems to have cause some problems with some users. Something you'll need to get in contact with Apple support about.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try setting CTS values to 2307 Under Advanced Tab/Advanced Settings/Wireless Settings
Retired_Member
Oct 20, 2021Modem is: Netgear CM500. I'm not sure I can answer the second part of your question. Wave Broadband is my internet provider.
