LonePalm's avatar
LonePalm
Product Model:R6120 throughput issues
I recently upgraded my ISP service to 300Mbps but can't get over 100Mbps. My NIC is brand new (installed today) and is configured for 1Gbps. When I plug the cable directly from the ISP into my NI...
  • LonePalm's avatar
    LonePalm
    May 22, 2019
    Thank you for your reply. It would have been better without the snark.
    No one can be an expert in everything and everyone misses something in the documentation at times.
    FWIW - When I started the Masters program it was Applied Math. They changed it to Computer Science just before I graduated in 1991.
    I do have a patent in Electronic Warfare (ECCM).
    Take Care and do try to be nicer to people who ask for help.
    LonePalm
