bordonbert
Jan 30, 2023Guide
PS121 Print Server PSU plug size
I have found this question asked a number of times before but never for a similar unit as this one. It's a PS121 Print Server, device name on detail sticker PS3A0591. I need a replacement PSU as th...
michaelkenward
Jan 30, 2023Guru - Experienced User
bordonbert wrote:
I need a replacement PSU as the original one is missing. It has the usual 5.5mm barrel plug but I can't tell if it is a 2.1mm or 2.5mm centre pin. At only 0.5A I'm guessing 2.1mm but that is just what it is, a guess.
There are still manuals for these things in the support library. But they are usually silent on tip dimensions.
In any case, you won't be able to buy a Netgear replacement, so it will have to be a generic adapter. These often come with a set of tips that will fit just about any standard devices. They look a bit like this:
Generic adapter
The manual says 9 V DC 0.5 Amps max.
