OldBob
Jan 02, 2020Luminary
ps4 speed wndr3300
We have enjoyed PS3 for many years and just got a PS4. When we turn it on, our internet speed goes from 30-50 mbps down to around 10 mbps or less on my laptop and phones. it gets so slow I cannot p...
- Jan 02, 2020
OldBob wrote:Thank you for your patience. I went to that site and put in Nighthawk s6s ac3600 and it could not find that unit. The model number is R7960P. I believe off what you typed. its X6S which is why the S6S didn't display anything
Can you provide a direct link?
https://www.netgear.com/support/product/R7960P
Can I indulge you for a couple more answers? Ill do my best
Can I rename the SSID to the old one I had and use that same old password? yes. I do this all the time because I change routers a lot.
Does this set up 3 connections so I have to choose each time which one I want to connect to or just one and the router deternimes what band to connect to each time I sign onto a network? It has the option of smart connect which lets you use a single wifi name and the router will move devices around based on bandwidth/distance from router. If you don't like that, you can always seperate them out. I like using smart connect but many don't.
I have tried to watch some videos and they are not clear at all. I was hoping it was all automatic and if I wanted to make any changes or check things out I could still go to 192.168.1.1 as needed (hopefully not) as I currently do with the WNDR 3300----You can use the 192.168.1.1 to set it up. Or you can use an app on your phone. Both options are availble. I'm like you and prefer to do it over the web browser. But either works. The website shows the app setup. I think the 3rd video shows the setup using a pc and not the app.
Jan 02, 2020Guru - Experienced User
The wndr3300 is pretty old. It was from 2007. So an upgrade certainly isn't going to hurt and might indeed show significant improvements depending on the speeds you get from your ISP.
the ps4 might be downloading updates/games in the background. when you have an older/slower router or slow internet speeds in the first place, this isn't going to leave much available bandwidth. Plus the PS4 is going to use more bandwidth during game play.
I'd check into a router upgrade as well as assessing what your ISP speeds are.
- OldBobJan 02, 2020Luminary
Thank you for your reply. I am 75 yrs old and hate new learning curves so can you maybe direct me to a better Netgear router. I have two laptops and two iphones and PS4 in a small ranch. I was looking at the Nighthawks with the three antenna. One says Gaming and one does not..$130-190. It seems I may not need the 6 antenna one for my small needs. Every sales person just wants to sell what they have alot of and to be honest..at my age they just dont really care to get technical for my needs. My cox input is 150 Mbps and I have a new modem too. I would like one that is easy to install and hopefully I can keep my name and password but probably have to change that. Any input for me would be appreciated.
As additional info..I may not need now but the 6 antenna one is on sale at Costco for less money $150! But I read somewhere the PS4 maynot work on it?
- plemansJan 02, 2020Guru - Experienced User
its not necissarily how many antenna you have.
What area are you trying to cover? Sq ft of house
What are the interior walls of your home?
What modem is it that you have?
These are kind of keys as if you have a larger home, mesh networks have been on sale and provide better overall coverage than a single solution. But if you're home isn't to large, a single router solution will work best.
And we ask what your interior walls are in your home because certain materials block wifi signal like plaster lathe, concrete, brick, etc. You have to take that into account as well as home size.
