stackem
Aug 10, 2016Aspirant
Purchased a WNR2020 and no longer able to play "LINE: Disney TsumTsum" game
I replaced my old equipment with the NETGEAR N300 Wi-Fi Router with High Power 5dBi External Antennas (WNR2020v2) recently and now I am no longer able to access the LINE: Disney TsumTsum game on any ...
- Aug 15, 2016
Just to update everyone, I did finally get this working (and I have no idea why it works). I set my DNS server to Google's public DNS servers and I'm able to successfuly connect to my game now. My ISP is Comcast.
stackem
Thanks for the suggestion...unfortunately still getting the same error and not able to connect to their servers to play.
Retired_Member
Aug 10, 2016if your ip was blocked it should had worked did you notice if your Public IP changed
- stackemAug 10, 2016Aspirant
My IP did change. Thanks for your suggestions, I must just not be meant to continue the addiction.
- wcalifas831Aug 14, 2016Prodigy
You can try resetting your router and see if that fixes it. Also try upgrading the firmware to the latest if you still haven't done so. Let us know what happens.
