JoeMcLutz
Nov 27, 2021Aspirant
QoS doesn't work on my DGN2000
Hi! I am a DGN2000 owner and I have no idea why QoS does not work: my pc always has the lowest priority (even if I put it at the highest) ... My brother's pc, when he downloads the files, does not e...
Nov 27, 2021Guru - Experienced User
Thats a pretty old (2008) device that i"m surprised even has QoS.
Its wifi is going to be anemic in speeds as its a old wireless G device.
And even its dsl speeds aren't going to be much. In this day/age, most devices are going to overwhelm it.
Not sure what speeds you pay for on your dsl but it might be time to look into upgrading.
- JoeMcLutzNov 27, 2021Aspirant
Hi.
Thanks for your reply.
I've firmware v1.1.11.0 which has QoS capabilities.
DGN2000 is fine for my ADSL speed (current speeds... yes, in 2021 it can still happen):
DownStream Connection Speed 15281 kbps UpStream Connection Speed 1018 kbps
I used a DGN834G (if I remember correctly) but it fried out during a storm... That modem router was excellent in managing QoS (even if it had no QoS settings feature).
