sbier's avatar
sbier
R4500 USB Control Center - Windows can't find NuDrvInst64.exe?
I'm running Windows 7 on a desktop and Windows 10 on a new laptop.  Having problems trying to install ReadShare for printing on my old desktop (with Win7), although everything seems to be working oka...
  • ElaineM's avatar
    Oct 03, 2016
    Hello sbier
    Welcome to the community!
    How about to completely uninstall the ReadySHARE Printer USB utility, restart the PC then turn off any firewall or any antivirus installed on the PC.
    Once done, reinstall the software then see if that will work.
