sbier
Oct 02, 2016Aspirant
R4500 USB Control Center - Windows can't find NuDrvInst64.exe?
I'm running Windows 7 on a desktop and Windows 10 on a new laptop. Having problems trying to install ReadShare for printing on my old desktop (with Win7), although everything seems to be working oka...
ElaineM
Oct 03, 2016NETGEAR Employee Retired
Hello sbier
Welcome to the community!
How about to completely uninstall the ReadySHARE Printer USB utility, restart the PC then turn off any firewall or any antivirus installed on the PC.
Once done, reinstall the software then see if that will work.
sbier
Oct 03, 2016Aspirant
Bingo - it worked! My original message neglected to mention that I'd already tried turning of my Norton firewall and AV - and also trying to install USB Control Center in/from Safe Mode. None of that worked, but your plan - uninstall USB Control Center, reboot the PC, turn off firewalls and AV and then reinstall USB Control Center - WORKED! And the ControlCenter itself works because now I can print from both of our PCs. MANY THANKS, ELAINE!
- ElaineMOct 03, 2016NETGEAR Employee Retired
That's great! Glad to hear that it worked!
You're very welcome.
Feel free to mark the solution.
