KDMThai
Mar 08, 2017Aspirant
R6000 to Virgin Media Super Hub 3 Connection problem.
HI All, Just taken Virgin Media out on a gamer bundle (yes I know stupid idea :-P) and tried plugging the above into all network ports and can't get a connection. Yet if I plug any device (Lapt...
- Mar 09, 2017
Hi KDMThai,
You can check the link below for the steps on how to setup the router in AP mode.
Dexter
Community Team
Mar 08, 2017Guru - Experienced User
I'm unclear on what you want to do.
Are you wanting to set up the R6000 as an access point, and use it's wifi instead of the SuperHub? Or something else?
KDMThai
Mar 09, 2017Aspirant
Yes need to use it as an access hub. But for some reason when I connect the super hub to the R6000 there isnt any internet connect.
