ThereseSmith
Jul 19, 2017Follower
R6020 as second router
I purchased the router thinking I would be able to establish a wireless intranet within an existing wired net. The reason is, I want to support a portable environment for teaching robotics, and the r...
- Jul 20, 2017
Hi ThereseSmith,
You may find the link below helpful when accessing the router UI to configure it manually.
http://kb.netgear.com/app/answers/detail/a_id/980
If you are looking to set it up as an access point, the link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/24104
Dexter
Community Team
DexterJB
Jul 20, 2017NETGEAR Moderator
Hi ThereseSmith,
Dexter
Community Team
DexterJB
Jul 23, 2017NETGEAR Moderator
Hi ThereseSmith,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
