Davidchini
Oct 26, 2017Follower
R6020 can not connect to wifi
Hello, I bought a Netgear R6020 from Walmart. It is not allowing me to connect to the internet on any device using wifi, and is popping up with a pink error message that state "403 forbidden" ...
- Nov 06, 2017
Hi Davidchini,
Have you tried resetting the device to factory defaults? If not, you can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
DexterJB
Nov 06, 2017NETGEAR Moderator
Hi Davidchini,
Dexter
Community Team
- DexterJBNov 09, 2017NETGEAR Moderator
Hi Davidchini,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
