AntonS88
May 31, 2021Follower
R6020 keeps loosing connection
I guess this is pretty hopeless since I already see threads about this with no solution. But I havent had this issues only with this model. It has been the same w/ previous models as well. It works...
Jun 01, 2021Guru - Experienced User
whenever you have more than 1 router having the same issue, you should look at your other devices.
What modem/gateway is it connected to?
are all devices having issues? Just one?
