Dodge63's avatar
Dodge63
Initiate
Jun 18, 2017
R6020 loses internet connection after 30min
I just bought R6020 which loses internet connection totally after 30min. The internet LED turns amber. The connection will not return automatically. I can reset the connection quickly from routers i...
  • Dodge63's avatar
    Jun 19, 2017
    I gave up. I returned Netgear to the store and bought the ZyXel router. Now everything works without any problems.
