utahraptor
Jun 20, 2022Aspirant
R6020 Not working after attempt TFTP fix.
Hello. My router was stuck with the power button flashing. I learned I could fix it by linking up with it via Ethernet cable. I messed up when typing stuff in due to my anxiety issues. It said the fi...
michaelkenward
Jun 21, 2022Guru - Experienced User
There is no such thing as the R6920 in the Netgear support zone.
I wanted to check to see what colour the power LED should be. White is the usual colour, but some devices are different.
The correct model number is important. Unlike the normal update process, TFTP may not warn you if you try to use the wrong firmware file.
- utahraptorJun 21, 2022AspirantYeah, oops. I mean R6020.
- michaelkenwardJun 21, 2022Guru - Experienced User
utahraptor wrote:
Yeah, oops. I mean R6020.That makes all the difference. That is one of the routers that uses a green power LED.
If it goes off completely, that is not the usual indicator of broken firmware.
