utahraptor
Jun 20, 2022Aspirant
R6020 Not working after attempt TFTP fix.
Hello. My router was stuck with the power button flashing. I learned I could fix it by linking up with it via Ethernet cable. I messed up when typing stuff in due to my anxiety issues. It said the fi...
utahraptor
Jun 21, 2022Aspirant
I tried to use nmrpflash but maybe I'm not too sure on how it works. When I run it, it just says a bunch of stuff and then prompts me to press any button to close the program.
michaelkenward
Jun 21, 2022Guru - Experienced User
That "bunch of stuff" is important. These processes aren't forgiving.
Everything has to be correct, especially the "path" information and where you have the files on your PC.
You have to read the messages and understand what they say.
In the case of TFTP there are some useful videos that guide you through things.
