Dsearle1122
Sep 02, 2022Follower
R6020
Bought second hand and can’t access admin password to set it up
- KitsapMaster
Dsearle1122 wrote:
Bought second hand and can’t access admin password to set it upThis should get you in:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Something to keep in mind is the R6020 is a base model 10/100mbps devices.
If you have speeds >100mbps, then you'd be better off upgrading to a device with gigabit.
