bgswsi
Nov 27, 2021Aspirant
R6050 AC7050 power light stays amber, no wifi
My R6050 AC7050 has worked the last few years. Now when i turn it on the power light stays amber, and none of the other lights come on. There is no wifi. User manual has no siutation where power l...
Nov 28, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
