Domingos
May 17, 2024Aspirant
R6050 Blocking websites seemingly randomly
I've just Facory Reset my NetGear R6050 & Changed ISP Router, at the same time, and since then I've been constantly blocked from "normal" websites quite randomly - ie.: NetGear, Reddit, Globo (major ...
- May 19, 2024
Domingos wrote:
It's basically to enhance signal reach, as the ISP Router doesn't get to our bedrooms.
I was kind of trying On-Off other settings, unclicked the Router as DHCP Server option... that may be bad?
That R6050 a pretty basic router from 10 years ago.
Your best bet might be to put the R6050 into access point mode and to let the main modem/router do the heavy lifting.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
michaelkenward
May 18, 2024Guru - Experienced User
What is that ISP router and how is it configured?
Is it also the device that connects you to the Internet?
How is the R6050 connected to the ISP router?
What firmware did you manage to install? And how? Only a manual install is likely to deliver the most recent.
- DomingosMay 18, 2024Aspirant
I did a manual installation of most recent firmware (NetGear JR6150_R6050-V1.0.1.26_1.0.1), downloaded from NetGear's website.
My ISP is VIVO, their modem is using stock configuration.
The setup here is: (Devices) -> Router -> ISP Device -> Internet
- michaelkenwardMay 18, 2024Guru - Experienced User
And that modem is?
I did a manual installation of most recent firmware (NetGear JR6150_R6050-V1.0.1.26_1.0.1), downloaded from NetGear's website.Two different routers, but they may have the same firmware.
ISP Modem is Microstar GPT-2741GNAC-N1
I think the firmware is the same: NetGear "JR6150_R6050-V1.0.1.26_1.0.1", i got it from NG' website
