Domingos
May 17, 2024Aspirant
R6050 Blocking websites seemingly randomly
I've just Facory Reset my NetGear R6050 & Changed ISP Router, at the same time, and since then I've been constantly blocked from "normal" websites quite randomly - ie.: NetGear, Reddit, Globo (major ...
- May 19, 2024
Domingos wrote:
It's basically to enhance signal reach, as the ISP Router doesn't get to our bedrooms.
I was kind of trying On-Off other settings, unclicked the Router as DHCP Server option... that may be bad?
That R6050 a pretty basic router from 10 years ago.
Your best bet might be to put the R6050 into access point mode and to let the main modem/router do the heavy lifting.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
Domingos
May 19, 2024Aspirant
It does find the Mitrastar GPT-2741GNAC. If that is what you have then, this is a modem/router.
That's the one 😬!
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point (AP) with a wired connection to the main router.
michaelkenward
May 19, 2024Guru - Experienced User
