John-Smith's avatar
May 12, 2022
R6050 with mixed wired ethernet speed LAN clients
I have an AC750 R6050 Netgear Gigabit router with the WAN port connected to a Gigabit cable modem getting 1Gbps internet service.  On the LAN side, I have a combination of 100Mbps wired ethernet clients (Smart TV and an old laptop) and a 1000Mbps (1Gbps) wired ethernet desktop and several WiFi wireless smartphones, tablets and notebooks.
All clients except for the sole 1Gbps desktop are getting internet service appropriate for their speeds; however, the 1Gbps desktop has to wait sometimes several minutes before an internet activity completes sometimes getting timeouts and errors.
The cables are CAT6 and CAT7.
Also, still connected to the router, the 1Gbps desktop can connect to a VPN and gets internet service as typical as a VPN connection can be; but if that is the case, what the heck is going on with the routing and could this be related to DNS conflicts of some kind?  Or is the router able to provision Gigabit speed to the 1Gbps desktop while also handling the various speeds for the 100Mbps and WiFi clients?
Thanks in advance for reading!
  • In response to plemans :
    Yes, at the moment only 1 Gigabit device is attached to the LAN side and according to the router "Statistics" is connected with a "Link speed" of "1000M/Full" which appears to mean that it is 1000Mbps = 1Gbps.  Also on the WAN side of the router to the cable modem the link speed is at "1000M/Full".
    The other wired devices on the LAN side, when they are on, their link speeds are only "100M/Full".
    • plemans's avatar
      on the gigabit device, what actual speeds do you get when testing?
      • John-Smith's avatar
        John-Smith
        Tutor
        In response for more information to plemans
        Speed tests:
        Case I: Normal (via router to cable modem)
            Testing time: 18m54s (real), 0m2.6s (user), 0m1.7s (sys)
             Download/Upload: 18.39Mbit/s, 30.13Mbit/s
        Case II: Normal VPN (via router to cable modem with VPN)
            Testing time: 22.2s (real), 3.7s (user), 3.3s (sys)
            Download/Upload: 145.35Mbit/s, 28.50Mbit/s
        Case III: Direct normal (direct to cable modem)
            Testing time: 23.5s (real), 4.9s (user), 6.1.s (sys)
            Download/Upload: 299.17Mbit/s, 28.85Mbit/s
        Case IV: Direct VPN (direct to cable modem with VPN)
            Testing time: 23.0s (real), 3.9s (user), 3.8s (sys)
            Download/Upload: 164.96Mbit/s, 28.01Mbit/s
        Note that in Case I sometimes the test will fail with "failed name resolution" and it is typical that the testing time does take around 20 minutes!
