WAMorgan
Oct 20, 2017Apprentice
R6050 Won't Install Firmware Update
Brand new R6050. I'm wanting to update it to the current firmware. It says it currently has V1.0.1.10_1.0.1; however, when I look at the available versions in the Downloads section of Netgear's web s...
- Nov 09, 2017
Ok, I've gone through Netgear's uncalled for harassment and they have updated their web site to indicate the correct firmware version. I've verified that the site is now showing v1.0.1.10 as the current version and that the router itself is no longer prompting to be updated.
WAMorgan
PS. As mentioned above, this is a brand new unit. I've never had one come out of the box with the current firmware on it. So, this makes me think, that while the problem appears to be a typo, it most likely is not. Any verifications?
cdlason
Oct 21, 2017Guide
I have a 3 year old R6050 router and also can’t install the update offered. I tried with the upgrade assistant and by downloading the upgrade. I tried for clarification from Netgear and was offered an answer for $139.00. Keeping in mind I could get a new one (same kind) for around $60, I was not going to pay that. I assumed they were taking advantage of the security situation to earn some extra money.
- michaelkenwardOct 22, 2017Guru - Experienced User
Have you read the conversation so far?
Can you tell us which firmware version you have?
What happens when you tried to install the firmware?
- cdlasonOct 22, 2017GuideI have the same current firmware version as the original poster for this discussion. When I try to install it all appears to be going normally. Says it is updating the settings but ultimately shows the same version I had before and still says there is an update available. I’ve tried rebooting the router, even unplugged it.
See this for my theory:
Re: R6050 Won't Install Firmware Update - NETGEAR Communities
Unless you have a better idea, I'd give up and wait for the next version.
Sadly, Netgear does not seem to be too keen to respond.
- AZtravelerOct 22, 2017Tutor
I have the same problem with a 2 year old unit. Have tried upgrading from the router's firmware update, manual download/install, and the Netgear Genie app (still shows V1.0.10).
Are you looking for help, or are you just adding a "me too" vote?
If the latter, thanks for confirming the problem.
If you are seeking an explanation, see above.
- cdlasonOct 22, 2017GuideLooks like a device wide issue of some sort. Hopefully WAMorgan takes advantage of the free tech support and finds an answer. I looked up the support number online and navigated my way through the endless phone tree but they can be reached.
