zeether7
Feb 11, 2022Aspirant
R6080 - opening ports does not work
I have been trying to open ports on my router recently to no avail on Windows 10. I logged into admin, opened ports as the guide said, but nothing works and canyouseeme can't detect the open ports. M...
Mar 05, 2022Guru - Experienced User
Any progress on this?
zeether7 wrote:
I have been trying to open ports on my router recently to no avail on Windows 10. I logged into admin, opened ports as the guide said, but nothing works and canyouseeme can't detect the open ports. My setup is just a modem from my ISP connected to the router, it isn't one of those router/modem combos. Do I need to set a static IP?
zeether7
Mar 06, 2022Aspirant
No, I haven't had any luck. I tried connecting directly to my modem as someone stated but it won't work, and I have given the model number and brand of it.
- DexterJBMar 09, 2022NETGEAR Moderator
Are you able to go online when connected straight to the ISP's modem? If yes, were you able to run the port check and what result did you get?
Dexter
