ChipMoody
Apr 17, 2024Aspirant
R6080 - Turn Off Router
Trying to use this just to connect a couple hardwired Ethernet devices and get to them from my laptop's WiFi. Box continually steps in and interrupts what I'm trying to do, complaining that there...
Apr 17, 2024Guru - Experienced User
- ChipMoodyApr 17, 2024Aspirant
Thank you FURRYe38 - dug into the menus, but apparently not deep enough - that did the trick!!!
Anyone else diving into this, make sure you READ THE WHOLE THING and scroll down to where you want to set your IP address settings BEFORE you reboot the router! (I didn't... That was fun)- Chip
- FURRYe38Apr 18, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
