Jump177
Dec 13, 2022Aspirant
R6080 Access Point remote access
Hi! I am using my R6080 as an AP. Is there a way to configure remote management so that I can reboot the device remotely? Thank you!
- Dec 14, 2022
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
By the way, even in AP mode the R6080 will slow down your network.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet, anything faster than 100 Mbps is a waste of your money.
It connects to your router at 100 Mbps, so that will be the fastest that you can get through any wifi clients that connect through it.
Dec 14, 2022Guru - Experienced User
Not in AP mode.
Why is a reboot needed?
