Wifizombie
Jul 23, 2021Aspirant
R6080 Firewall isn't operating correctly
Recently, I've been having an issue with all my devices, and my R6080 router. A few days ago, I tried to enable a Port Foward. When I found out the packets were still being dropped, I tried to enable...
Jul 23, 2021Guru - Experienced User
what device is having issues?
All of them?
One of them?
How are you testing packet drop?
is it happening over wifi?
Over wired?
What modem/gateway is it connected to?
Does it have the same packet loss if directly connected ot the gateway?
- WifizombieJul 23, 2021Aspirant
Hi,
Currently, as far as I know, it's on all my devices. I'm using the generic Windows packet tool with some generic port scanners. It's connected to an Arris modem, and it's over wireless and wired. I can't connect directly to my modem.- plemansJul 23, 2021Guru - Experienced User
Which arris modem?
And why can't you directly connect to the modem?
The modem is much older, and I can't get a model number, since I'm currently not at my house.
