Wifizombie
Jul 23, 2021Aspirant
R6080 Firewall isn't operating correctly
Recently, I've been having an issue with all my devices, and my R6080 router. A few days ago, I tried to enable a Port Foward. When I found out the packets were still being dropped, I tried to enable...
antinode
Jul 27, 2021Guru
> As far as I know, the values are the internal IP of the host, the TCP
> or UDP service, the external and internal port range, and service name.
Strangely, I still can't see any of the actual values which you might
have specified for anything. "the host"? Are you running some kind of
server on your (unspecified) "the host", or what?
> [...] I used the Command Prompt (ping + telnet) to execute commands to
> determine the status of a port. [...]
Which part of "actual actions (commands) with their actual results"
did you find confusing? Copy+paste is your friend.
> [...] It's an Arris TM822.
Whew. That's a modem, not a modem+router. Should be harmless.
> [...] I can't access a web interface for it, as far as I know. [...]
Have you tried "http://192.168.100.1/"? But with a simple modem, I
doubt that it matters.
> For the usual problems with port forwarding, see:
> https://community.netgear.com/t5/x/x/m-p/1859106
Did you read any of that, or answer any of the questions, or perform
any of the suggested tests? Or am I talking to a wall, here?
> You might also want to consider answering some of the many
> still-pending questions.
Still true. Look for "?". Here's one example:
> [...] Is there some actual problem which you are trying to solve?
Wifizombie
Jul 27, 2021Aspirant
The problem I'm trying to solve is for the packets to arrive at my computer. I have a Netgear R6080 + Arris TM822. When I try to connect to google.com for example, the connection is unable to open. When I use telnet, this shows up. (I used port 1578 as a random port, for this test.) Connecting To www.google.com...Could not open connection to the host, on port 1578: Connect failed. This is the problem.
P.S.: I'm not a computer expert, so some of the imformation is difficult to interpret. Please bare with me.
- antinodeJul 27, 2021Guru
> computer. [...]That's meaningless. _Which_ "the packets"?
> [...] When I try to connect to google.com for example, the connection
> is unable to open. [...]Are you trying to say that using some web browser or other, running
on some computer/device or other, a (partial) URL like "google.com"
gives you some error or other?See "As usual, [...]" above.
> [...] When I use telnet, this shows up. [...]
"this"? "When [you] use telnet" _how_, _what_ "shows up"?
> [...] Connecting To www.google.com...Could not open connection to the
> host, on port 1578: Connect failed. [...]I have no idea what that means.
> [...] This is the problem.
I don't know what "This" is.
> P.S.: I'm not a computer expert, [...]
I'd already guessed that.
The less you know, the more important accurate, detailed, precise
descriptions become. What you see, what you did, and what happened when
you did it, are what matter. Non-descriptions like "unable" (or anything
involving "packets") often convey little or no useful information. (In
this case, "no".)After not getting a straight answer to the most basic questions,
repeatedly, I'm worn out. Perhaps someone else has more time to waste
this way than I.
