q002837
Mar 19, 2023Aspirant
R6080 Firmware Update to v1.0.0.45 - Basic Tab functions do not work. Reboot does not resolve.
R6080 Firmware Update to v1.0.0.45 - Basic Tab functions do not work. Reboot does not resolve. GUI is version different than firmware version. Is this expected ? How does one resolve the issue ? H...
q002837
Steps to take ?
Log into the router, click the BASIC tab.
Nothing on it functions. ie: click on a function on the menu... it does nothing.
Mar 20, 2023Guru - Experienced User
Did you try a factory reset?
If you're having issues after upgrading firmware, its one of the first troubleshooting steps.
